'66 merc 110 - won't stay lit
rustvyper
I've been breaking a sweat over my grandfather's old merc 110 for a week now. Finally got it to where it will start, however, it won't stay going.<br />I've checked these things...<br />-plugs are new<br />-engine is getting fuel as far up as the carb float (I've taken apart the carb & cleaned it)<br />-gas tank & fuel line is new.<br />I've even gotten it to run at full power for a few seconds (have it sitting in a big tank of water.) But it never takes long to cut out & die.<br />I'm at loss for what to do other than perhaps replace the plug leads? Any other ideas? Any help would be appreciated...Thanks!
lark2004
Re: '66 merc 110 - won't stay lit
try the merc forum, the post will probably get moved there shortly.<br /><br />a few small points, is the timing set properly?<br />Has it had a link and sync?<br /><br />N.B. Don't ever rev the engine to full power in a barrel. Engines need to push into a load (prop in water) when being reved up. In neutral in a barrel of water, don't push it above 1500 - 1700 rpm.
JB
Merc Troubles.
