Re: 66 Starcraft Sunchief Re-Build
SS, My wife picked the colors. We were looking for something old skool so we're gonna do the waterline down and turn up the bow with a sort of sea green. Looks kinda like this
The side will be white and the top will be the same green. I had to buy green and white from Pettit and I'll just have to wing it on mixing the color. We'll se how that goes. Once I have the final mix, I'll spray a 6"x6" peice of metal and take it in and the automotive folks will match it for me.
So I fired up the heater in the shop overnight to ward off the overnight chill. Went out and shut it down around noon. Threw open the big door, hit a few rough spots with some 5oo grit (very lightly) and wiped the entire boat down with a damp cloth.
Next step was rigging all the danged air lines to get to the boatel. Once that was accomplished, I broke out my Home Depot Husky brand gravity feed HVLP spray kit. I bought it a couple of years ago and have never used it. Man that setup is simple! One dial for air and one for material.
The directions on the primer said 15 to 20 % spraying thinner so I mixed up 16 ounces of primer and 2.5 ounces of thinner and hit it with the paddle. Poured it thru the strainers that came with the gun and went at it. That initial mixture did one entire side, half the bottom, and half of the stern. Started sputtering right at mid point on the stern.
I did have a little trouble with the gravity feed right at the back on the bottom where it gets real flat, but had no problems with the deep V hull.
Mixed another batch and shot the other side. Here's a few pics.
I think it turned out good for a spray challenged boat owner. I plan on hitting it with a tack rag in the morning and shooting another coat of the primer. Then I'll sand it with the 500 grit on Sunday and try to paint the first coat on Monday. You folks tell me what you think of that approach?????
BTW, SS, the plan was to start low and work up.
