North Beach
Thread starter- Joined
- Sep 29, 2008
- 2,022
Re: 66 Starcraft Sunchief re-Build
OK it?s Friday night and me being the homebody that I am, I decided to party hard and go out to the garage and apply the Gluvit to all the seams and rivets.
The plywood decking has been sanded and another coat of resin applied to the bottom so we?re gonna be re-installing the deck soon.
Here?s a shot of the resin and catalyst. This is a 5 to one mix so the boat is 22 feet, with one seam down each side and about 1.5 million rivets in the hull. I decided to basically attack the stern and everything below the waterline. Remember, this was a bone dry boat to begin with and the decision was made to go with the Gluvit as a precautionary measure. So I mixed up 8 oz of catalyst and 40 oz of resin and had about ? coffee cup left over at the end so a gallon of this stuff is enough to accomplish just about whatever anyone would want to do.
The material looks sort of grey in the bucket but goes on like a milky clear. Looks just like the resin we applied to the plywood. The can says it dries clear and you can paint over it.
Basically I just slathered it on with a small brush and it self levels. The brownish stuff you see there is called Goodyear Pliobond, a liquid rubber installed when the boat was seamed originally (at least that?s what the brochure says).
After it sets for a few moments you can go back and brush the pools of material over the area again and you?re basically done.
The can says optimum temperature is 72 degrees. It?s about 65 in the shop so we?ll give it a few days to totally cure and it?s time for new flotation and back in with the decking!!!!
Now I feel like I?m accomplishing something!
