Yep, covered by Bob...also, the new JB WaterWeld tube .....its kneadable putty ..sticks anywhere..I've wrapped it around broken tiller/motor mount....lay down supports..like a rock now ...The cover is for the exhaust water and if you repaired it with JB weld it should be OK the cover bolt break off quite easily if you try to remove them and you could never weld it if it'e corroded thru
