'67 Merc 650 sputters when hitting choke
sutor623
So guys just wired up my new choke and key switch. I was very careful to keep all wire ends from shorting on each other. Choke works great, key switch works well. I was jiggling things around before I tightened up the box and evertything was fine. If I turn the motor off and hit the choke button within a few seconds afterwards the motor stutters. Of I wait 5 seconds or more before hitting the choke it does not make a noise other than the choke click. I just want to make sure that this is normal and that I don't possibly have a short somewhere. The starter is not turning. I wonder if the vacuum that the motor makes is still in action and sucks fuel in the second I hit the choke.
Re: '67 Merc 650 sputters when hitting choke
Ayuh,.... If the motor is still turnin' over, yer causin' a rich condition, which leads to dieseling.....
If the motor ain't still turnin' over, it shouldn't do a thing...other than the click...
sutor623
That's what I was thinking. Why do you think it does this right after I turn the motor off?
Ayuh,... 'n What might that be,.... I offered Two(2) options,....
I can only read what yer writin',...
Not what yer Thinkin'.....
mercurymang
Are you saying that you shut the motor off, then you hit the choke and then motor shutters (after it has completely come to a stop)? If so, can you define the shutter. I mean is it turning over or something? Not sure I understand.
sutor623
Well I was thinking that with the motor completely off it shouldn't do a thing when I hit the choke, but that's not the case.
sutor623
Yea, right after the motor comes to a complete stop if you hit the choke within the first 3 or 4 seconds of the motor coming to a complete stop it sounds like the motor wants to start back up. It does NOT turn the starter, just sounds like it wants to turn back over. If I wait more than 5 seconds before I hit the choke again theorize doesn't make a peep other than the choke click. I will also add that the motor runs very well and on e it's warmed up it only takes a very brief turn of the starter to get her turnin. I just want to make sure that I don't possibly have an electrical issue here....
mercurymang
Well I'm not exactly an expert but this is an interesting problem. So let me dig into this statement: "it sounds like the motor wants to start back up". So the motor turns over but doesn't start?
sutor623
Yes but whatever is starting it to turn over is not the starter. I will put a video on her if I need to
M
Maxz695
Guest
Hey dude your key switch is sticking in the start position. Spray some WD40 in the key hole a few times and it might stop. No but seriously you either have A) a terrible wiring job B) a bad kill switch ground or switch or C) Time for a new starter soleniod
sutor623
Ok well wiring is clean and starter is NOT spinning. I just figured out that the little muffle it is making is trying to spin backwards. What would make a cylinder try to fire in reverse when the motor is turned off and quickly the switch is turned back on and choke is hit?
Ayuh,.... I've got a better question,.... Why in 'ell would you do such a thing,..??
Yer inducing run-on, or dieseling.....
Keep it up, 'n a bent rod will be in yer future.....
jimg984
ahot carbon spot will ignite fresh fuel by uneed choking,,,,, u need to pee and go to bed and forget it
sutor623
I figured it out on accident. When I noticed it it started to make me wonder. I don't **** around with my stuff I just didn't know if it was a problem or not. I was simply checking for a short in my control box.
sutor623
Thanks this is the answer I was seeking.
