Any salt evidence or not ...if not sure post pictures.Thanks for the prompt replies. I have both a 1/4" hex impact and a 1/2" pneumatic, but think maybe I'll try to work them loose by hand first after employing the loosening techniques already mentioned. I'm not really expecting trouble, but my personal life lessons have proven to me that there is always that ONE damned bolt........
Just me but I dont like using impact drivers on corroded stuck fasteners. There is a skill learnt of previous disasters where one can tell the difference between a bolt that is actually unscrewing and one that is twisting to breakage....you loose that advantage with impact drivers.......you will however get better at removing the broken bolts.Thanks for the prompt replies. I have both a 1/4" hex impact and a 1/2" pneumatic, but think maybe I'll try to work them loose by hand first after employing the loosening techniques already mentioned. I'm not really expecting trouble, but my personal life lessons have proven to me that there is always that ONE damned bolt........
In the case of salt, that's exactly right. Your trying to break it up or break it down.... Braking the bond.heating the bolt allows a heat transfer to the engine's bolt threads and body
in effect releasing the bind on the bolt itself . This is what happens in the
ball-and-loop physics demo. The ring expands when heated and allows the ball to pass the inside circumference of the loop. thankfully aluminum expands more than bolt steel !
The applied heat to the bolt does not shrink the bolt to break the bind. The engine's aluminum body expands outwards .....releasing the bolt.
my understanding anayway![]()
Never smack two hammers faces on each other. A piece of the steel can break off. I never believed that till I found myself with a pencil eraser sized piece of steel buried deep in my forearm still have the scar 40 years later.Penetrating oil and a 1/2” pneumatic impact gun is my go to. Turn air pressure down a bit to loosen up any crud in the threads before going full force.
If that doesn’t loosen them, I use two ball peen hammers to break it loose.
Place the small end of one hammer on the head of the bolt and hit the face of the hammer with the other.
Mechanic friend turned me on to using a “bolt breaker” tool with an air hammer. Works like a charm
Quality ball peen hammers heads are forged and hardened, even tempered some times, specially for metal working.Never smack two hammers faces on each other. A piece of the steel can break off.
Yes, forged ones are the best...drop forged even better.Quality ball peen hammers heads are forged and hardened, even tempered some times, specially for metal working.
Unlike cast steel, a forged head is highly unlikely to splinter or shatter upon impact.
Worked in the metals industry my entire life. Learned early on quality over quantity.Yes, forged ones are the best...drop forged even better.
Unfortunately, I just grab the closest hammer... because I have more than I can count.
I use my hammers. It’s all the other tools I’ve collected over the years.Nothing wrong with a tool chest full of hammers.
