68' 55hp Rude: 5 year maintenance
Thunderhawk
Hey everybody quick question, gonna do a little more to my motor this year aside from the normal: fog cylinders, gearcase oil, lubricate pivot points ect...
Gonna check: fuel lines, carb nuts, low speed needle adjustment,new impeller, new plugs, link and sync, fuel pump screen, decarb, compression test
( before and after decarb?).
Am I missing anything?
Should I pull fly wheel to check points ect...?
Been about 5 years since I went through this motor, runs real strong now,
NO real issues, Thanks for any input.
Thunderhawk
Re: 68' 55hp Rude: 5 year maintenance
By the way motor sees less than 25 hours use per year thanks.
rileykrommendyk
NO real issues, Thanks for any input.[/QUO
I know that this has nothing to do with your 5 year maint. but i have a 1970 60hp and i was jsut wondering if you could take a pic of the starboard side of the motor or even jsut tell me where the wires go comming from the CDI box i cant find anything anywhere thanks a bunch
Thunderhawk
Try "mustman65" he's got one just like yours, if u still need help let me know.
tashasdaddy
replace all your fuel lines with alcohol resistant lines, Ethanol,, eats the interior of the old ones, and cloggs the carbs.
Thunderhawk
What about pulling the flywheel to check points? It dose run good now though.
