Re: '68 ?? 6hp evinrude lower unit removal
I have a 6hp 1966 Evenrude, which should be identical to yours. It has been a year or so since I had the lower unit off but as I remember it, you have to really pull on it.<br /><br />You don't have to remove the roll pin (this is the impellor drive pin) at this time. <br /><br />At this point, you have two options. You can pull on it and work the drive shaft out of the Powerhead, where it goes inside a splinned hole. or you can remove the gears and drive the driveshaft out of the pinion gear, bushing, seals etc. Dried grease is what holes the drive shaft in the gearbox, and corrosion is what holds it in the powerhead.
