68 alumnacraft transom/decal help
07browninglariat
I have a 1968 14' almunacraft boat and am in the process of restoring it. the back transom is completely rotten and i figured, no big deal, i'll just remove all the nuts/bolts/screws and be able to remove the board....i was wrong. i'm assuming i need to drill the rivets by the back handles in order to remove the aluminum bar in the back, is this correct? as far as replacing the rivets, should i just use stainless stop nuts/bolts? i'm going to replace the board and add tompson water seal as well as a compressed hardwood to prevent the motor mounts from "breaking the wood seal" in the future. i also am looking to replace the side decals, "ALUMNA" is in block lettering, and "craft" is in cursive, i have checked out ebay with no results. please post some links to threads if possible, i searched and havent found much useful. i live in wisconisn if that helps letting me know where to find a place for the decals....Thanks!
