I have a Johnson 9.5 model MQ-14E. I believe this is a 68? Anyways, I just put new plugs in it - old ones were in bad shape! I checked the fuel filter - looks good. When it runs, it does great at higher RPMs but it will not idle down. Just cuts off. Then i have to pump the bulb and even choke it at times to crank it. The fuel line is good also. I have adjusted the rich/lean knob on the front to where it runs best.
Now, is there any other adjustment on the carb I can do? I'm sure it could use a rebuild but trying to see if I can smooth it out anymore for using it this weekend. I read where people mention pulling the bowl off and cleaning that part out - where is that on the carb? I cannot see where that is on this motor. I need to buy a service manual for this motor.
Anything I can clean, check, adjust for now on it?
Thanks!
Warren
Thanks!
Warren
