wrfalpacas
Thread starter- Joined
- May 1, 2009
- 486
I dove into the mix yesterday and started tearing out the floor. I will need to replace the transom wood, as well as the wood in the cabin and cabin walls. Basically if it is wood, it is gettin replaced. And there lies my first question. It appears the floor was 1/2" plywood. and either I need to replace with same or raise the threashold of the door and the walls 1/4" to fit thicker flooring. Suggestions? I need to remove the outdrive and motor to change the transom (and replace the wood front bearing plate), so do i pull the head and have the valves and seats replaced to run unleaded? I will have to repaint inside and outside and am planning on using roll in bedliner on the floor and exposed interior sidwall areas. I need to buy new seating and build a new doghouse as well as rebuild the cabin interior. wow that seems like a mountain of work ahead of me!
I will be posting the before and initial tear out pics soon. the mice turned the foam into one big exploded beanbag chair
-Bret
-Bret
