69 Alumacraft
Thread starter- Joined
- Nov 15, 2009
- 173
LU is stuck in gear so I took off and drained the oil. It seems to be jammed. I have another LU that shifts fine but leaks. I suspect it may have something to do with the spring loaded detent in the shaft but that is pure speculation.I plan to take it all apart inspect the parts and put back together. Any advice on what may be causing this issue is appreciated.
