'69 33HP Johnson ignition problem?
Hoyt79
The motor has new ignition switch and solenoid...can't figuere out why it won't start with the electric start. Maybe a loose wire or broken wire?
Joe Reeves
Re: '69 33HP Johnson ignition problem?
When you turn the key switch to the start position, what does happen?
How are the terminals marked on the back of the ignition switch?
