69 evinrude 155 hp need help wiring key up
tony11905
i have a 69 115hp evenrude electric shift/push button control. that i need to wire up to the key ingntion but i dont know what wires go where, there is only {1=black wire/1=purple w/white stripe/,1=yellow/, 1=purple,/,and 1=red/ but there is one gray wire,and another purple wire that comes from the control harness also does this wire from the control get connected to the ingtion?
rayodunne
Re: 69 evinrude 155 hp need help wiring key up
Are you sure that wire is yellow? On my push button there is 2 purple, 1 white, 1 red that go to the ignition key. The gray wire is for your tachometer.
tony11905
sorry your right it is white. so where do i begin what wire goes on what,and the purple wire from the push button control where does that hook on to
