Re: '69 Evinrude 55HP w/ Selectric switch will not reverse
Yes, I do. Per the instructions in my manual, I disconnected the green and blue wires at the powerhead where they go down into the lower end. I tested both ends of the wire. To clarify, with the switch in the forward position, I tested the disconnected wire back at the power head and grounded off the other lead. I got no voltage(good) and tested the blue with the same results. I then switched the box to Neutral and tested again. Green showed 12 and blue showed 0. So, finally I switched to Reverse and tested both wires. Both had 12V. So, according to the manual, that eliminates the switch and all wiring leading to it as being the problem. I then turned my attention to the continuation of those wires that lead to the solenoids. I tested the OHMs of the blue wire/blue solenoid and grounded the other lead and got 5.8OHMs. That is within the 5-7 range that the manual specifies. I then tested the green one and grounded the other lead. And guess what? No reading could be displayed. I tested multiple times and confirmed a good ground, and still got nothing from the lower end green wire.
The reason my initial test was flawed was because the green wire's circuit was interupted (cuz the solenoid/wires leading to it was bad) and no current could be pulled through the switch. So no reading would show on the green spade connector in the switch. As you know, unless a circuit is grounded or complete, electricity will not pass through it. So that was my problem here. The switch is fine, the solenoid, or wire leading to it, is bad.
Next question. Were is the solenoid grounded out at? Is it simply touching the metal inside the lower end, or is there a wire coming from it? Obviously checking the wiring first is the best option instead of replacing the solenoid.
Could this still be caused by bad oil? Since water could cause a short, could I still be looking at a problem other than the solenoid itself? I will be draining and changing the oil tonight to check for water(which I understand will show up white).
