Re: 69 Evinrude How to replace coils,condensers,plugs ,and points
If turning the slow speed needle has no effect, then your idle passages are clogged or there is a vaccum leak.
There should be a little red nylon piece that the needle threads through and sits inside the opening where the slow speed needle goes. The nylon piece has a little tab on it that keeps it from turning while you adjust the needle. If it's missing or damaged, that could be part of the problem. I would take apart the carb, remove the low speed needle, and clean it by squirting some carb cleaner through all the passages. DON'T try to take out the high speed orifice. It requires a special screwdriver to remove it. Just blow it out really good with some carb cleaner. It should be o.k. since you said your motor was running o.k. at wide open throttle (WOT).
WHen you get the carb right, you'll probably really love your motor.
BTW, they all put out that crud in the barrel. ALso, in your pic, you don't have nearly enough water in the barrel for the water pump to prime properly. It needs to be about 3 or 4 inches below the hole in the back of the midsection where water spurts out (it's called an exhaust relief).
GOod luck,
JBJ
