chiefcatchemall
Thread starter- Joined
- Jul 24, 2009
- 197
Hey all. New to the Forum. Seems like a pretty neat site. Anyways I just purchased a '69 evinrude sportwin 9.5 hp outboard motor. They guy I bought it from hasnt run it in about 5 years. I took out to a local lake when I first got it and it ran great. No problems. The second time I took it out I had a bit of a problem. It ran great for the first hour then it started running like crap. It wouldnt run unless the choke was out and when I pushed the choke in the engine would die. So I took it out into the backyard and stuck it into a trash can of water. Same thing at first and it also threw a lot of smoke and it made a popping/skipping noise. We finally got it to run without the choke on. We sprayed the carb down with a bunch of carb cleaner. I believe the 24:1 gas/oil ratio the guy told me to run in it was wayyy to lean. So me and my father diluted it with some more gasoline. Anways once we sprayed the carb down and diluted it a bit it seemed to run much better. So yesterday I took it back out to the back yard and stuck it in a trash can of water. It seemed to run great for a half hour or so then it started making the popping/skipping noise. I decided to dump the old gas out and start with new fresh fuel. I also drained the gas line. After talking to a bunch of guys they all suggested running a 50:1 ratio. So thats what I did. At first it still made the popping/skipping noise. It did this for about 5 minutes. It was getting dark so i put it all away. This morning I went out and put it in a can of water again. It wouldnt run unless the choke was pulled out. I finally got it to run with the choke off about 5 minutes later. After that it ran good. About every half hour I went back out and fired it up and it would start the first pull. I dont know anything about outboards so I was wondering what the problem sounds like to you guys? Thank you in advance...
Andrew
Andrew
