69 johnson?
jethro66
Hey guys wats Up/ I just bought this really nice johnson for 200 CAN. today! It started on the second pull and the bottom end has been serviced,But he said it needs a thermastat? I noticed when I started it The bulb goes soft ,does it need a fuel pump? The nubers i got on the side is 25203R C 58947 ? is there more #'s I did not see it on ken cooke Please help!!
AlanR
Re: 69 johnson?
Does it stay running if the blub is soft? The thermastat is usaly ontop of the cylinder head and isa little square box. If it needs a thermastat it might not pump water to cool the motor. Id check out see if its pumping water out the side were it should come out. If its not then it prob needs a impeller or a thermastat. If it dosnt stay running while the bulb is soft then it prob needs a carb kit and a carb cleaning.
Hope this helps
Alan
JB
Re: 69 johnson?
The model number, 25203, is for a 1972 Evinrude 25hp, Jethro.
Must have swapped bonnets sometime in its life.
jethro66
Re: 69 johnson?
Thank you!! JB!! On the lower end i see oil leaking in a little piee hole, is this normal? Thanks Alan1
Paul Moir
Re: 69 johnson?
You're likely looking at unburnt fuel/oil there. If it's just a little hole that's a weep hole to drain water out of the exhaust sections. Take a little in your fingers and smell it. Gas/burnt smell is unburnt fuel/oil. Lower unit oil has a strange smell which is hard to describe, but it's different.
Worth replacing the lower unit fluid anyway soon to see if there's signs of water intrusion and just to change the oil.
