'69 Merc 200 20hp-idle problems
Drindin
I've had a few problems in the past and got advice to pull carb and make sure it was clean, jets clear, etc. I did that. Now here's my(& others)problem: I have to squeeze the bulb to gas tank until I see gas coming out of carb, and then it starts fairly easy. But, to keep it from dying I have to continuously squeeze the bulb, JUST BARELY, like I'm keeping time. As soon as I stop, the motor dies 5-6 seconds later. I'm sure I need to replace the diaphragm; it has small dry-rott area with small hole. I've also replaced fuel lines but see a small amount of gas leaking from the elbow on fuel pump side of hose feeding float bowl. I'm beginning to have more than average problems locating parts too (all "No longer available". Any advice on that as well?
AMD Rules
Re: '69 Merc 200 20hp-idle problems
Sounds like you've isolated your problem to the fuel pump and fuel lines. Any hole, is a hole that is too big.
As for parts availability, you should be able to find kits for that fuel pump & carb. Fuel line is available off the reel at most marine places. If you really get stuck, you may find alternate sources for unique parts on eBay; even used parts may help in some instances.
Drindin
Drindin
Thanks. I had an idea but needed someone to to say "yeah, that's the right direction".
james33
Try just replacing the actual primer bulb itself.....teh 1 way valve may be jammed starving the cab of fuel... also make sure your fuel filkter isnt jamedd with gunk.....if this engine has a mercontrol lever system make sure the neutral throttle is wide open for about 10-20 seconds to ensure teh engine is warm... I have the same engine in the 1973 model and im having loads of problems with it..
Laddies
Banned
You need to install check valves as well as a diaphram, if the checks are bad the act just like the problem your having. Most of your lines and connection are alright or they would leak as you pump the bulb
