FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I can see that it took a while to find because of: the broken paint around the screws on the timing cover, homemaid gaskets on the thermostat housing and the rear end cap of the manifold, 1 odd spark plug, new manifold gasket, etc.
Are you telling me that the shop that did the work gave it back to you as described above?
It's good that they took the time to get it fixed (if they did in fact fix it) - but it sounds pretty shoddy to me.
While you have the engine out and everything is easy to access and remove, you might want to think about doing the re-route of the cooling for the exhaust. I will do a quick search and post what I am talking about.
Re: 69 Mercruiser 165 inline six rare problem done everything please help!!!
Yeh, it really ran like they timed the new cam wrong. Now it runs great!!! And I did get a new set of springs installed out of the deal. I also put in a new flapper in the exhaust pipe while the engine was out the second time. Now the fun stuff: acc. batt, aft cover, interior lighting. Before the not fun: gel coat repairs, water soaked foam, fresh plexiglass.
Back the rocker arms all the way off of 5 and 6 get a compression tester and remove the check valve in the extension hose. put air pressure on 6 and listen to the exhaust and intake. If you hear air hissing you have a vale problem, if you hear air coming from 5 you have a blown head gasket.
Also try and back the valves off. MArine high lift cams like the 165 only need to go down 1/2 turn after the click goes away. The valves may be floating slightly due to being too tight.
