Watermann
- Joined
- Jan 12, 2013
- 13,860
When I had my tank custom made I had them put the fuel pick up in the aft end of the tank with the level sender. The fill and vent were on the forward end. I wouldn't open up the tank or try to modify it, I would just put the tank in with the fitting end aft. If you need the fittings forward for some reason like deck clearance for the lines then I guess you could swap ends but the fuel pick up will starve with the tank is low on fuel and the gauge will read empty sooner. Also the tank has baffles in it, so it won't slosh and I doubt you can shove a longer pick up into the tank past them. I think the pick up is a rigid tube with a screen on it too rather than a flexible hose type set up.
