oldhaven
- Joined
- Aug 30, 2015
- 581
The topic of how to install gauges with your new Merc is different than older analog outboards, but really is made simple in some ways since it is a Smartcraft system. You could simply do it the old way and buy an analog gauge and hook it up to the tank, but then you won't be using some of the nice things the Mercmonitor does like GPH and optimizing fuel use. You need to get a Mercury Smartcraft Fuel/Paddle/Oil Boat harness if it did not come with the motor package. It plugs into the engine under the cowl and has a sender wire that will work with any standard tank sender. it also has a connection for a paddle wheel speed sensor. The engine senses the fuel level in the tank then reports the fuel state and other data to the mercmonitor via the harness/cable that runs from the engine to the Monitor. There are several display functions in the Monitor that report fuel level, or you can have a system linked digital gauge that plugs into the Monitor harness. I felt that I had invested quite a bit on a "Smart" engine and a Mercmonitor, so I should take advantage of what it could do digitally. I notice that you also have a Smartcraft control, just like mine. I had to spend a lot of time learning how these things work, but luckily there is quite a bit of information right here on iboats:
http://forums.iboats.com/forum/engin...rtcraft-system
After my mind got unbent from all the reading, It all went pretty simply.
If you do not have the harnesses or have a dealer that does not understand these things, (it happens a lot), and want to do it yourself like I did then PM me and I can give you the name of someone who can help with supplying the right harnesses and advice you need.
Ron
Ron
