So, I just inherited a 1969 9.5hp Evinrude Sportwin model 9922S. It's had the carbs gone through last year(or possibly the year before), water pumps been checked last year and was fine, changed out the spark plugs for new onces this year, got a new fuel line for the tank so that I didn't have to worry about leaks with the old one. The problem is, that there doesn't seem like there's alot of resistance when you pull to start it and it takes alot of pulls before it starts. Once you get it started it doesn't want to idle well, but it seems to run fine at WOT, and good at lower speeds. but again, once you start trying to idle at normal RPMs it sputters a bit and dies.
what I was wondering is, what could be the problem?? Think it would be rings(compression) since there's really no resistence when you're pulling to start the motor? I haven't had a chance to check compression on it yet.
