Sarasota flYour location ?------If in Canada-------evinrudeparts.ca-----May offer help.
ThanksEvinrude Johnson 386692 piston 0376994
Part # 376994
$70.00
386692
1 in stock
Seaway Marine
Don't know if they still do or can, but when I worked for NAPA, we could take old rings, measure and match up a set. Since all rings in your motor show to be the same, you only need to match one. Just a thought.Thanks
Not sure if this is just the piston or assembly including rings which is what I really need. I think I may get by with the existing pistons just need those rings![]()
HmmDon't know if they still do or can, but when I worked for NAPA, we could take old rings, measure and match up a set. Since all rings in your motor show to be the same, you only need to match one. Just a thought.
I'm sure their machine shop can measure pistons and rings. I also found your rings on line. Does your motor use 1, 2, or 3 rings per hole?Hmm
You think they can measure on pistons?
Two rings per holeā¦I'm sure their machine shop can measure pistons and rings. I also found your rings on line. Does your motor use 1, 2, or 3 rings per hole?
I looked just about everywhereTwo rings per holeā¦
