RPJS
Thread starter- Joined
- Jul 29, 2002
- 1,572
Model 6BA79E
I have fitted a new impeller, the pump body and base plate were both in very good condition.
When started the motor pumps little or no water and overheats quickly. If I remove the plugs and turn the motor over with a hand drill it pumps loads of water, replace the plugs and try again it stops pumping. The water level in the tank is well above the pump, there are no blockages in the water pipe or passages.
My first thought was a head gasket leak allowing cylinder compression to pass into the water jacket, I pulled the head fitted a new gasket skimed the head 0.005" reassembled and still had the same problem. The compression is OK 105/99.
I have run compressd air into both cylinders at 70psi and found no noticable leaks.
I think I need to be looking elsewhere for the problem but I'm not certain where to start, anyone got any ideas?
Thanks
Thanks
