tango13
- Joined
- Mar 10, 2015
- 84
Hi all,
Earlier this summer, my 95' Cougar was starting to refuse starting when warm. Its got a carbed 454/Bravo 1 drive. The block and bottom end are almost new, 25'ish hows (0.30 over with an upgraded cam, built and installed by reliable people). Anyways, it would fire right up every morning as it should and run fabulous.. until it was shut off. After about 5-10 minutes, when I would go to start it, it would just crank and crank and crank.... no start. I tried WOT and everything else when cranking, but it just wouldnt catch. After sitting at the dock for 45-1hr later, I could get it running again but it definitely put up a fight. Once I got it running, it would puff out a bit of black smoke and run a little hard, acting like it was flooded but eventually smoothing out.
I did not check for spark when it would only crank over with no fire. The carb is a Carter AFB. I thought the ignition was a TB4, but I see a knock sensor so I'm guessing its the TB5?
My current thoughts are: Carb is dumping gas after shutdown, vapor locking bad, or some sort of ignition issue when its warm (though I'm skeptical on this as it runs like a dream even when hot). The motor is completely factory other than the bottom end.
Anyone ever encounter this?
