rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Hi,
Trying to help a family member with a new to him boat. 1998 Sea Ray 33 express with twin 7.4 Horizon MC inboards. We have done a lot of research on the topic and understand the interrelationships of AID, Throttle plates, TPS etc....We replaced AIC's for a Sirge/Stall symptom because when throttling back to dead idle (in Neutral), sometimes the motors would stall. The New AIC's seemed to fix the stall Sympton, and that area was fairly Grungy.
However, what we are left with is the same "lope" or "surge" we had. if you remain in Neutral, and bring up the RPM some. IDLE is fine at 6-700 with no surge. But if you just bump up the throttle a bit, there is a very noticeable fast surge up and down. This occurs while bringing the throttles up to about 1200-1600 I believe. After that the Surge seems to settle out. The same exact scenario occurs on Both ingines.
While still tied up, we put it in gear (under load) and cannot replicate the Surge...Seems to be only in Neutral without load.
SO THE QUESTIONS ARE THIS:
1) Is any of this normal. (other posts seem to indicated it "can-be") My feeling on this is that those that believe it is, have just not got to the
root cause. CURIOUS.
2) What have others done, or looked deeper into to solve similar described Surge issues?
The motors only have 500 hours on them, are very very maintained (we have all service records). All hoses and clamps are good. Throttle plates appear fully closed at idle. (but have not examined their motion at different throttle positions).
NOTE:
This boat was brought from its purchase location, to home-port on a rough trip through New England open-water 113mi, in April and ran flawlessly. This doesn't seem like a usability issue, as I cannot see many scenarios where you would be much above Idle in Neutral. Again, Doesn't seem to happen In-gear under load. But it is annoying. Why doesnt a fuel injected automobile do this if it is a normal behavior here?
NOTE:
