rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
Helping out a family member (I'm the outboard type) but do alot of the maint on his boat...He purchased this 1yr ago and got a successfull season out of it so far......1999 Sea Ray 34 Amberjack w/dual 7.4's.
These are Coolant cooled blocks, with Raw water to the mani's and Risers...Its time to replace them. Ive done extensive research and have learned a ton, including known water ingestion issues related to this motor setup.
I dont now what the original design was that might have had issues, But his now has a fairly tall riser, with a 3-4" adapter block between the Mani and riser. The riser output angle might be the 7degree model (but not sure yet), and the tubes going down to the mufflers have a significant length and angle pitch to the mufflers. The exhaust openings are on the side of the boat vs transom. He runs wet style mani/riser's. I havent measured but the waterline to riser top is appx 18"+. Apparantly dry joint manifolds/risers are not available for the 454 7.4's. Would like to move to that as it makes alot of sense, but so far bieng told not available. Unsure why.
The biggest questions we have if anyone has knowledge about this or experience:
* Does this setup sound exposed to the design issue with water ingestion problems?
* Is there any recommendation further?, such as riser output angle increase?
