7.4 MPI exhaust manifold plugs leaking
Mischief Managed
Each of my exhaust manifolds has a pair of Torx (huge Torx) head plugs installed on the side that faces the engine. They are located above the exhaust ports. 3 out of the 4 on my engine are leaking water. The manifolds seem to be in good shape otherwise. Is this common? Should I remove them and seal them up, or buy new manifolds?
dubs283
Re: 7.4 MPI exhaust manifold plugs leaking
i would try to remove and seal em
new manifolds is expensive
Pete104
They could be "plastic". When you have them out, look at 'em real good. If they look like they have been HOT, replace them. Engine may have been overheated at somepoint.
Mischief Managed
They are indeed plastic. I think I will replace them. Good advice.
Anyone know what size Torx driver they take? It's a whole lot bigger than any I have.
boat127
t-55 or a t-60 can't quite remember but one of those two
