I've got a 1998 Glastron / Carlson boat, 23.4 feet, CSX-23
It's powered by a 7.4L Magnum MPI motor.
The boat looks nice, has 125 hours on it. I'm the 3rd owner.
I bought it in "guaranteed" mechanical condition - after some testing a GPS and an inductive tach, I found that I had a problem - top end in 52mph range. I gapped and changed the plugs, ran compression, new plug wires, new cap & rotor - same issue, top end of 52mph at about 4600 rpm (off the top of my head).
I didn't have the tools to run the EFI diagnostics. I took it in to my local marine dealer, that rechecked all my work (nice, eh?) and found that it had a "bad injector". Replaced that injector and the boat ran much better. Top end 61-62 in calm water, full tank of fuel.
My guaranteed boat went silent after a $600 repair bill.
Results now:
4700-4800 rpm, 61-62 mph, 23 pitch Mirage Plus prop. Bravo-I outdrive.
Calculated prop slip is 11%. This is good performance, but not to spec.
This boat tested out per a boating magazine at 68.5 in rough water fueled. Same motor - same outdrive. I'm well shy of that mark in smooth water. I'm thinking that the 6-7 mph difference is probably 50hp or more on a boat like this, so I wonder if I don't have something wrong still.
I know how to work on EFI systems - I just have no idea of what I need to do on a boat, as I don't have an 02 sensor to look at for output and don't really have the expensive Mercruiser diagnostic tool....
My suspicion would be the injector set - the injectors are not a recirculating system like they are on cars, so any crap that gets sent up in the fuel is going to stay in the injectors.
I can pull them, have them professionally cleaned.. But I'm just guessing, and I hate to guess... Any ideas?
Results now:
