Re: 7.4L Mag MPI Performance Issues
In a boat, with a non-circulating fuel system, it sits in the fuel line until it's let out of the injector(s).
I agree with you here. I suspect if I do have a problem it's in the injector(s). Seeing as I've had one injector go "bad" - which is a very odd thing to happen in my experience, I need to figure out if it was a clogged injector or truely a bad injector. A single clogged injector might indicate that it's worth pulling and having all 8 professionally cleaned.
As these have non-circulating fuel systems, I'd like an opinion on how "common" injector issues are.
The vehicle I have available for experiemental tuning is turbo'd - so I can't really test the WOT theory. I can say that tuning naturally aspirated things, using an electronic gauge that read off of the MAP sensor, at WOT I'd see near zero manifold pressure, if I recall correctly (which I may not be recalling correctly)... and it would not deviate if air/fuel mixture was off. I have logging that can provide information to the same accuracy level that a MAP sensor can read...
I'm not sure that they're just on there so we don't burn out a catalyst. Modern turbo vehicles are configured from the factory to run pig rich (safe) under boost - I think it would take a ton of fuel - enough to really make the vehicle run badly to foul a catalyist.
I do believe they are on there for the sake of fuel ecomony. They measure stoich, which is leaner than peak power. Closed loop, vehicles adjust to 14.7:1 at cruise... Leaner than that, you can feel it. Many modern vehicles also have a "learning" capability to shift the entire fuel map up / down based on 02 feedback.
A 2nd opinion is good. No issue there, but let me take a 2nd or 3rd run at you too. I would ask where does this fuel go if it is being pumped out of the tank at correct WOT rates? Assuming you have good compression, no big broked parts, nobody with a vice grip on any of your drive partsand no fuel leaks, unless timing is off, the only place for low power is an intake air restriction or some sort of fuel supply problem. In those last two cases then you would have low WOT fuel rates or I guess crap fuel . . .
Ahhhh, but you're forgetting about "absolute pressure", you have to count Atmospheric pressure too, zero is Gauge not absolute . . . that's how it knows how to adjust for altitude which is another good question . . .
Edit: I see your 1 ATM there now, but I am not sure why this is relevant?
O2 sensors are there to provide perfect stoichiometric burn ratios so that you don't foul a catalyst. We are talking teeny weeny tiny variations of rich/lean ratios if the ECU is mapped properly and the MAP sensor is good . . .
