7.5 evinrude 1955 model# 7518
UPRON
Can I put electric drill on drive shaft with LU removed and placed in a bucket of water to check to see if impellor pumps?
lindy46
Re: 7.5 evinrude 1955 model# 7518
Sure can! That's how I check them. Make sure the water pump housing is submerged, and best to check with the copper water tube (or any other tube which fits in the pump housing grommet) attached so you can see that water squirts out of the tube. Rotate clockwise as seen looking down on the lower unit.
