7.5 Fleetwin carb adjustment
z3beld
can anybody tell me the initial carb settings for high and low needles on a 7.5 fleetwin aquasonic? Any help would be appreciated, Thanks!
greatoutdoors
Re: 7.5 Fleetwin carb adjustment
If you have it running and idling, turn the low speed needle in slowly and allow for some time for the motor to adjust to the change. When it starts to bog or not run properly turn it out slowly and stop as soon as you get a nice smoothe idle. Do the same thing for the high speed needle when on the water at full throttle. Then play with it a little until you find a spot where you think you are getting the highest rpm's. Seems to work for me. I think there are universal initial setting something like "start with the low speed 1 full turn out" or something of that nature, but I find it best to do it the way I described. Some needles could be a little worn and one turn out is not the same fuel delivery volume as others. Hope it helps.
Joe Reeves
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
