freddyray21
Thread starter- Joined
- Jun 10, 2006
- 2,460
1954 Evinrude 7.5 hp. Motor pumped water good when I first got it, but lower unit was full of water. I pulled the lu and resealed it also putting in a new impeller. Now it won't pump. I know the impeller is working as I pulled the power head again and used a drill to turn the drive shaft. I have a very good flow out of the tube. The only thing I can think of is something got into the water passages. The old impeller was in good shape no pieces so it's not that. I did use a bit of sealer on the power head gasket when I put it back together probably stupid seeing my current issues. Do I need to pull the head to find what is blocking it? I pulled the side cover and did not find anything in there.
