7.5 HP intermittent miss at WOT
huntin dawg
Hi Gents,
I finally got my 1973 7.5 HP out for its first full test run after it's rehabilitation. She runs great except for an intermittent skip/miss at WOT. It pushes my little jon boat at 16 MPH which is pretty impressive.
Any ideas why it misses at WOT?
Thanks,
HD
verado7
Re: 7.5 HP intermittent miss at WOT
only way to know for sure is to test the ignition with a dva and or you can check the resistance on the stator - check plug wires - sounds like switchbox or stator though .
huntin dawg
What is a dva? I haven't done any ignition work.
HD
CDI Tech Support
DVA Explained
DVA is a highly accurate measurement. But you must have a digital meter with a DVA Adapter attached.
This should be our troubleshooting guide for your engine:
Mercury 1 and 2 Cylinder - 336-4516
If not, obtain the ignition part#, then check here:
CDI Troubleshooting Guide
Since the problem is occurring at high speed, it could be that the high-speed coil is breaking down. Check resistance from Blue to Yellow. It should read from 170-180 ohms.
If you find that it's out of spec, we suggest replacing both the high-speed coil & low-speed coil at the same time while you have the ignition apart.
If it's within spec, the ignition itself could be in need of repair. We offer Repair & Return for the 336-4516 ignition.
Again, if this isn't the correct ignition, obtain your ignition part# (or serial#), then check our troubleshooting guide page for the correct guide.
huntin dawg
Thanks for all of the input.
The miss is very intermittent and only when at absolute WOT. If I back off just a tiny bit it stops missing. Could it possibly be a synchronization problem?
HD
CDI Tech Support
HD
You would need to confer with a qualified marine mechanic.
huntin dawg
Synchronization was the problem. All it took was about 1 1/2 turns of the max advance screw to fix it. I'm sure glad I didn't buy new coils.
HD
CDI Tech Support
HD
That's why we always suggest taking it to a qualified marine mechanic to have all mechanics checked prior to any ignition checks or changes.
Our troubleshooting guides/procedures are assuming all mechanical checks have been exhausted.
