7.5 Merc 1970 or 71 3197XXX
kysunfish
I have tackled this project to the bitter end and have came a long way from where I started. Rotten wires, cracked insulators and cracked fuel pump. Fuel lines and connectors all a mess. I'm trying to figure how I'm going to connect the new wires to the hi tension studs inside the insulators. The original one that was intact was soldered in what looks like a screw driver slot. Also once this is together need to set the new points and get everything ready to put the flywheel back on. If anyone could offer some incite it would be greatly appreciated
Ayuh,..... Welcome Aboard,..... I believe that slot is to unscrew the terminal,.....
Can't find a decent picture, but did find This, that might help,....
