7.5 seahorse re-coil start
superspark
Anyone have any tips for fitting the cord around the drum. I have rewound the spring
14 turns and held it in position. Now I cannot get the cord to go the first turn around
the drum and into the slot. So many things seem to prevent its progress.:(
HighTrim
Re: 7.5 seahorse re-coil starter
What motor?
superspark
Hi Chris. Its a 7.5 1980 seahorse twin.
Joe Reeves
(Manual Starter Cord Installation)
(This pertains to the vertical type of Manual Starters such as the 9.5hp and later 4.5/6/8hp models etc)
(J. Reeves)
1 - Have a pair of vice grips handy set so that they will grab the top of the starter spindle tightly but will not damage it.
2 - Using a large screwdriver inserted into the top of the starter spindle, wind the starter in a counter clockwise direction 12 to 14 turns, stopping so that the cord locking slot is facing the away from the engine.
3 - Lock the spindle in that position with the vice grips, letting the vice grips lay against the flywheel.
4 - Insert the cord as needed and make sure it is retained properly at that slot.
5 - Feed the cord out the starter cord hole at the front of the engine and attach the handle.
6 - Grip the cord tightly so that the spindle cannot spin around rapidly, then release the vice grips.
7 - Allow the cord to be withdrawn slowly around the spindle.
superspark
Hi Joe, Thanks for that. Holding the drum with vice grips seems like a great idea. I still have the problem of getting the cord
around the back of the drum however. Maybe I will remove the vertical bar at the back which guides the cord . Hope fully this will make it easier.
Thanks again for your advice.
Joe Reeves
Removing that vertical bar is a bad idea!
