70 Evinrude, water between PH and shaft
Doop
I have a 70 hp Evinrude, 1978. Runs good.<br />I changed the impeller last year, water runs out the pisser just fine and motor is cooling properly, however lots of water is exiting just between the power head base and the drive shaft housing. There is actually water inside the cowling at the bottom. Almost no water is exiting out the exhaust.<br />I found some previous posts for this but they were all mercs.<br />My manual does not give enough information to show the water path in that area. :confused:
Doop
Re: 70 Evinrude, water between PH and shaft
Forgot to add, this problem was apparent before and after I changed impeller.
angus63
Follow from the exhaust port to the powerhead and there probably is an exhust leak. There was a recent post on this and I will see if I can find it for you.<br />Good luck
