70 hp 1980 johnson fuel
starcraft69a
I put sea foam in my fule and went out boating. I trolled for a hr or so and pulled up and took off accross the lake she was running sweet slowed her down to put on jacket and had a huge power loss gimped her home. Now it seemed like a cylnder was down checked spark looks good. pulled the cover off the carbs and found that the #3 carb (bottom one) was putting alot of fule out the front of it not like the others what would cause this what is plugged in it I took the carb off blew it out and remounted still same result any help please?
jtexas
Re: 70 hp 1980 johnson fule
You mean the carb is spitting up fuel while the motor's running? That's a reed problem
If gas comes out the carb throat when you pump the primer bulb, it's just a leaky float valve. Rebuild with new kits is the answer.
Do you mean you added seafoam to old gasoline?
starcraft69a
sea foam was in good fule and yes ity spitss when running and no leak when pumping bulb
starcraft69a
what reed prob are you talking about
jtexas
A reed valve is basically a hole covered by a flat piece of metal, attached to the intake manifold, opened by crankcase vacuum to let air/fuel in from the carburetor, closed by positive crankcase pressure so the air/fuel mixture can be passed to the cylinder when the intake port opens.
There's a set of these behind each carb. When they wear out or break & can't close completely, fuel blows back out the carb instead of going into the cylinder.
Go to http://shop2.evinrude.com/Index.aspx?s1=fnafup8n36j6ketdot8r235tm5&catalog_id=0&siteid=1
Select "Johnson" in the dropdown box, then select your year/hp/model #. The picture below is from the "Intake Manifold" chart.
If a piece of a reed has broken off, you need to find it before it gets sucked into the cylinder and blows up a piston or something.
They aren't that tough to get to, just pull the carbs & manifold, but you want to make darn sure it's not just a leaky carb before you tackle 'em. A bad reed will literally spit gas back out through the carb, as opposed to say, just pooling in the throat.
If you take the carb off and shine a light into the hole you might be able to tell if something is lodged in there, or if there's any obvious deformity. I don't believe you can really inspect it without pulling the manifold. I don't believe you can re-use the manifold gasket, btw.
Handle the reed cages with care -- don't push on the reeds with fingers or anything else, if they get bent, they're toast. Held up to the light, you shouldn't be able to see through 'em -- it's ok if you can just see light peeking though, but there's shouldn't be any gap.
If you don't have a repair manual, I highly recommend the factory service manual. You can get one at www.marineengine.com
starcraft69a
I belive the reeds is it. It dose spit gas out the front not just pooling. I have noticed more drip out of the intake cover it seems worse when trolling I will let you know the results. And thank you so much I love this board ask a good ? and get a sound answer. Once again thank you jtexas for a quick ansewer
starcraft69a
Fixed and running well! Once I took carbs off I found A screw fom the air cover came loose and fell in the # 3 carb and was lodged in the reed assy. It allmost look like it belonged there. I took her out yesterday for test run and she ran like a champ. Once again thanks guys
Dhadley
You probably don't know how lucky you are. Today is your day to go buy lottery tickets.....
starcraft69a
I do know if it sucked in booooom by by motor
