70 HP rough idle
smittylv1
1983 70 HP Blue band with a rough idle.....power and top end is good 5000 rpm
Question: Should I adjust idle mixture? What's the best way? I do a lot of low speed trolling with crank baits.
1nebel0
Re: 70 HP rough idle
First is your timing setup correctly...Are you carbs lync and sync...lastly adjust idle mixture in gear tied to the dock..Best way and most accurate way...if you get a stumble when you goose it, you are too lean and turn out each screw 1/4 turn more(richer)...
