70 hp rude acc power?
chsintail
ok heres the deal i have no acc power when i turn the key to on and i dont know where to start looking ive checked selocmarine.com i might as well ask my dog their web site sucks not worth the money any help would be great thanks
F_R
Honorary Supreme Mariner
Re: 70 hp rude acc power?
Well, how about the rest of the circuits? Does it start and choke? If that stuff doesn't work either, check the 20 amp fuse. But if that stuff does work, just not the accessory terminal, then bad ignition switch. You didn't say what year 70hp. We're shooting in the dark here.
chsintail
everything els works the motor is like a 90 or 89 i havent checked the choke but it turns over. the +(tan ) acc wire that comes off the power head runs in to another harness theres a tan wire that has a funky conn on it that dead ends next to the coil packs and the rectifer i tested for cont. and the dead ended wire is hooked to the + for acc power but i dont know where the dead ended wire goes or where to test where key on acc power comes from? thanks for the help
