OzzieOzzieOzzie
Thread starter- Joined
- Mar 11, 2010
- 11
Need help. I have a 70 Johnson 1994 model which is dropping the no 1 cylinder intermittingly. It doesn?t do it at full revs and works fine until your drop down to trolling speed or stop. When you restart the engine it starts fine but stalls when you go to take off. If you gradually increase the revs as you are taking off it will either kick it life and run great or stall. This is what has been done so far.
? Carbies remove stripped and cleaned. There was a little water found in the float chambers.
? Had steam coming out of cylinder when spark plug removed. Head casket replaced and head machined.
? Water separator filter replaced
? All compression checks done and passed
? Fuel pressure checks passed
The problems is still occurring????
