70 Johnson question?
AFishin69
I am talking to guy who is willin got sell me his 70hp inline 3 with Hydro electirc shift.. are those reliable?? he says it has 120lbs on each cylinder.. is that good.<br /><br />He also has a 69 Johnson that is hydroelctric shift.. 100lbs on each cylinder both need keys... where can I get keys and I have heard the elctric sfhits suck is that true?? What do you guys think?
D
DJ
Guest
Re: 70 Johnson question?
AFishing,<br /><br />Unless you are VERY mechanically adept, I would stay away from both of them.<br /><br />If the electro shifts were are working, they are OK. However, if they go out, they can be difficult and expensive to repair.
AFishin69
What about the compression that sounds good right??
Solittle
Compression is fine on both motors though I it would be better if the 69 were over 110 lbs (maybe needs decarb). As for the keys - you should be able to get them from a dealer. Look for a number somewhere on your ignition switch.
papasage
i have a 63 eletric shift and have owned 2 others . never had a problem with thim . you use a different oil in thim than the mechanickle shift . what year modle is the motor you are looking at. papasage....... <br /><br />ps i have changed a 50 hp 1963 eletric shift to a mechanickle off a 64 50 hp.
