70 vro swap
seminol7
1997 johnson 70,wanting to swap out vro with regular pump.my motor does not have a place to bolt the pump on the block,i was told to buy a remote pump with 3 ports in,out,and crank case tube.does anyone know what part# pump this would be from iboats?thanks for any info!!
tashasdaddy
Re: 70 vro swap
Replacing Vro pump
You can use any of the following 3 line pumps
0385784, 0395712, 0398385, 0433390, 0438559 these are all BRP pumps, there is not an after market pump. You have fuel inlet, fuel outlet, and the pulse fitting, that was used from the Vro pump you will have to make a bracket to mount it on.
seminol7
Re: 70 vro swap
thanks for the information but i can not find the part #'s on iboats page,i really wanted to buy from them,but if they don't have it what web site can i buy them from?thanks for the help
