704 controls and actuator problem
AQUADJ
I have twin 1998 Yamaha 250 hp ox66 outboards that are controlled by 2 stations. When I put the starboard engine in "forward" from either station, an alarm sounds. This happens when the engines are running or not. When I disconnect the Pink wire from the wire harness at the actuator, the alarm stops. Any ideas?
rodbolt
Re: 704 controls and actuator problem
readjust the TPS settings on the box. the transfer box is sensing a failure in the system. it should also be kicking itself into netural as well.<br /> something is out of adjustment. I think the 03 Rigging guide has the adjustment procedure in it.<br /> the transfer box has a "TPS" in it similar to the one on the engine, do NOT play with the one on the engine.
AQUADJ
Thanks Rodbolt. <br />Can you tell me what the "TPS" is exactly. I have a 2000 rigging book that mentions the proper voltage to the unit but doesn't mention TPS.
rodbolt
not out of memory, I wont even attempt it.<br /> but there is a section in one of them that details the installation and adjustmet procedures.<br /> having installed and serviced them I can tell you to read and understand what does what BEFORE any adjustments are made.<br /> you will also need the TPS test harness and a digital voltmeter.<br /> basically its a 3 wire potentiometer. black is ground and orange is a 5Vdc reference and the pink is a voltage pick off wire. the other pink is for the alarm system.<br /> the pick off voltage is fed back to the transfer box, if the transfer box senses a failure or incorrect signal it sets the ground for the alarm and shifts into nuteral.
AQUADJ
Thanks again for the help.<br />Any idea what would cause this unit to go out of calibration? I recently disconnected the second station and when I reconnected it, the starboard tachometer wasn't working and the actuator was sending an alarm. Do you think the tach not working can cause the actuator problem?
rodbolt
if the same power feed or ground that is still dissconected from the tach feeds the transfer box I guess it could.<br /> double check all your harness connections.
