Just got carb kit today and getting ready to rebuild all three carbs. Motor has been bogging and not getting above 2500/3000 rpm. I got a small portable tank and ran good gas through and was still doing the same thing. In draining the fuel bowls I notice the bottom carb drain had some funky blue/green stuff on the end of the drain screw, so I order the kit.
My question is......... got any advice on the rebuild.
Do I need any special tools. I order the manual with the kit.
The manual said to use gasket sealer on the float bowl gasket. It's rubber, should I use the sealer.
Think I can manage the rebuild, but the syncro afterwards looks a little tricky.
Any advice from the pros/guru would be taken to heart.
Thanks
Thanks
