70hp merc 3cy from 1979, has new pack trigger stator and a working set of newer coils good gas and the carbs freshly cleaned. I cannot think of anyuthing else to do to get this to work. the power pack is grounded as it should be
the boat sometimes will take off to almost 4800rpm and die out from there, ive had the boat over 5000 before when it worked and held steady,
any help needed I cannot figure this out, it seems to run with 1 and 3 plug wire on as well as 1 and 2 wire on the same, as if both of those cylinders were getting a weak spark.
compression is all over 125psi
help
help
