70hp fuel connection
yowiie
hi guys
What is the hose connection that is directly under the fuel line connection on a 70 hp evinrude
there us the nirmal 2 pin connection and under it us a hose connection that will take a 3/8 hose
emdsapmgr
The VRO oil line is special 1/4" oil hose, with a yellow stripe running along/down the side. Special 1/4" squeeze bulb, too.
flyingscott
I don't know about it being special I just replaced my sending unit hose and all with factory parts. No yellow line on it and just looks like regular 3/8 fuel line regular fuel line. 1986 70 hp evinrude.
If you have just bought this motor you may want to mix oil with the fuel at 50:1 until you are sure that mixing unit is working properly !
emdsapmgr
Most folks don't know that Bombardier makes special oil hose for the VRO tank. Not sure just how well fuel hose stands up to delivering oil over a long period of time...
flyingscott
What I bought was a factory BRP sending unit assembly complete with oil line no yellow stripe on it.
emdsapmgr
BRP sells 1/4" oil hose in the following configurations: bulk oil line p/n 778707 sold off a 25" roll- yellow stripe. Oil line squeeze bulb p/n 5008620
