Re: 70hp johnson waterpump
i am currently changing the pump on my 1977 johnson, 70EL77S.
before the change, there was only a tiny stream of water coming out of a hole just above the lower unit. it was too low for a tell tale in my opinion. there are also two holes right under the engine cover facing straight back. those had tiny droplets coming out but nothing compared to a steady stream.
where would the tell tale hole be in my engine?
p.s. when i removed the lower unit, the pump was a mess and looked totally burnt up. havent recieved the parts to install the new kit.
