imported_mnmike
- Joined
- Jul 9, 2006
- 7
I just got a used boat and 70 HP Johnson. owner said it was winterized 2 years in a row. Motor is very clean. When run in a tub it took a minute or two to fire then it ran great, pumps water great. On the water, it ran for 15 minutes and then lost a bunch of power, tried different tank, fuel line, lowest plug was not hot like 1 and 2, finally found a coil pin plug (lowest cyl) almost out of the connector, pushed in and boat ran great for 1.5 tanks. then again power loss. Messed with connector again and got a few more good laps but then power loss. Could this be a coil issue? Power pack issue? Carbs looked very clean in the bowl. Float needle perhaps? I would appreciate any ideas.
Thanks,
Thanks,
